Viewing a list of InForm Adapters
You view a list of InForm Adapters from the Adapter List page.
- Select Admin > InForm.
If more than one InForm Adapter is installed, the Adapter List page appears and displays a list of InForm Adapters. If only one InForm Adapter is installed, the InForm Admin Adapter page appears.
- To view a list of end points, click End Points.
The view changes to a list of end points for enabled adapters and displays the following information:
- Adapter—Name of the InForm Adapter for the InForm end point (trial).
- URL—Location where the adapter is installed.
- End Point—InForm trial for the adapter.
- Status—Displays a green check mark if the end point status is OK or a red X if the end point status is Error.
