Field
Description
View
- Adapters—The page displays a list of adapters.
- End Points—The page displays the list of InForm trials that are associated with an InForm Adapter.
Enabled Only
- If selected—The list of adapters shows only adapters for which the status is Enabled.
- If not selected—The list of adapters shows all registered adapters.
Auto-refresh
- If selected—The page refreshes automatically at the interval specified on the Settings tab of the My CIS page.
- If not selected—The page does not refresh automatically.
Adapter
Name of the adapter.
Classification
Information about the product type, the adapter type, and the adapter version.
Ping status
- Green check mark—CIS Administration can communicate with the adapter.
- Red X—CIS Administration cannot communicate with the adapter.
Adapter status
- Green check mark—Adapter status is OK.
- Red X—Adapter status is Error.
- Gray circle with a line—Adapter is disabled.
Enabled status
- Yes—Adapter is enabled.
- No—Adapter is disabled.
