Changing the enabled state of an InForm Adapter
When adapters are removed from your environment or when the computer where an adapter resides is offline, you can change the enabled state of an adapter.
- Select Admin > InForm.
If multiple adapters are installed, the Adapter List page appears. Click the row of the adapter you want to view and manage. The Adapter tab of the InForm Admin Adapter page appears.
or
If only one adapter is installed, the Adapter tab of the InForm Admin Adapter page appears.
- In the Enabled group, select Enabled or Disabled.
- Click Save.
