Changing roles associated with a user
You can change the roles granted to a user and the domain associated with the role. The roles are used to create an association with a user, a role, and a domain.
- Select Settings > Security.
The Security Administration page appears with the Users tab selected.
- Click the row of the user you want to change.
The Edit User page appears with the Profile tab selected.
- Select Roles.
The Roles tab appears with the Modify Roles button selected and a list of current roles.
- Click Modify Roles.
The Modify Roles view appears.
- If you want to change the domain with which the role is associated, select a domain from the Filter Domains drop-down list.
- In the Granted column:
- Select the checkbox for each user you want to associate with the role.
- Deselect the checkbox for each user you want to remove from the role.
- Click Save.
