Viewing roles and associated domains for a user
- Select Settings > Security.
The Security Administration page appears with the Users tab selected.
- Click the row of the user you want to view.
The Edit User page appears with the Profile tab selected.
- Select Roles.
The Roles tab appears with the Modify Roles view selected.
- Select View Current Roles.
The Roles tab displays the domains and roles that are currently assigned to the user.
- If you want to change the view based on domains, select a domain from the Filter Domains drop-down list.
