Corresponding Clintrial and InForm metadata objects
Clintrial study book attributes, context parameters, system parameters and various object properties correlate Clintrial metadata objects to corresponding InForm metadata objects.
Clintrial metadata object |
InForm metadata object |
Protocol (type 1 only - clinical data protocol) |
Study. |
Study book |
Study version. |
Page template |
Form. |
Page section (panel types 0, 1, 2, 3, 4) |
Section. |
Items |
Item. |
Derived item |
Calculated control where the rule defined for the calculated control will reference the name of the DEPP. |
Field label |
Item question. |
Repeating items |
Itemset. |
Codelist associated with an item (aggregated, unaggregated) |
Radio group, checkbox group, or pulldown control, depending on the number of entries contained in the codelist and the options specified when importing the protocol. |
Codelist associated with an item (view) |
Single radio button with label text Empty View Codelist. The reference to the codelist is preserved in the properties for the item in the data mappings object. |
Checklist associated with an item with Override attribute set |
Radio group containing:
In-panel master-detail page section |
Itemset. |
Cross-panel master-detail page sections |
Itemsets (many side) and items (one side) with panels and panel relationships defined through mappings |
Date field, complete |
Date field. |
Date field, incomplete |
String field. |
Rule or derivations |
Rule of type Clintrial Rule or Clintrial Derivation. |
