Panel Types and context items
The Clintrial software uses panels to represent the database tables that store clinical data. Panel types support the data entry activities for a protocol. Panel types, panel and page section attributes, and context parameters are determined during study design using the Clintrial Design module.
The following table lists the Clintrial panel types.
Panel type |
Usage |
Example |
Type 0 |
Non-subject data |
Lab normal ranges |
Type 1 |
1 record per subject |
Demography |
Type 2 |
Previous Meds |
Type 3 |
1 record per subject visit |
Physical Exam |
Type 4 |
Labs |
Type 5 |
Subject enrollment |
Enrollment |
