Context panel item updates
You can change the definition of a CONTEXT panel item by changing its mapping definition in the Central Designer software. Because CONTEXT panel items are appended to all Clintrial data tables, you change only the panel item definition. Changes must follow the standard rules for changing item definitions:
- The new item definition must have the same TYPE property as the previous item
- If you change the item size, you must change it to a larger size.
- When the CIS software receives a valid new CONTEXT panel item during synchronization, it applies the definition to all panels in the Clintrial protocol.
For more information, see the Central Designer guide Working with Rules and Logical Schemas, in the section CIS mapping properties.
