Mapping date time controls
You can set up CIS mappings for date time items so that:
- The entire data appears in a single database column in the Clintrial database.
- Each date time part appears in a separate database column in the Clintrial database. To split mappings for a date time item into date part components, you define a separate data series and mapping for each date part. The mappings that the Central Designer application generates include the DATEPART attribute of the CTITEM tag.
For more information, see the Central Designer guide Working with Rules and Logical Schema, in the section Setting up CIS mappings for date time items.
