Working with mappings from the Central Designer software
When you develop a study with the Central Designer software, you can use a logical schema to generate Clintrial mapping definitions for processing by CIS. (In the Central Designer software, these mapping definitions are called CIS mappings.)
When you create a deployment package and choose one or more logical schemas to use to create CIS mappings, the following mappings are created:
- Each data set becomes a panel, and each data series becomes an item in the panel.
- A custom data dimension on a data set is mapped to the Subset Item in the Clintrial application. Only one custom data dimension is supported for each data set.
- The Panel Type is defined by the value of the Panel Type CIS custom property on the data set.
- Other panel and panel item attributes are defined by the values of CIS custom properties on the study event, form, data set, and data series.
- Only normalized values mapped to the Clintrial application.
For more information, see theCentral Designer guide Working with Rules and Logical Schemas.
