PANEL mappings
In an automatically generated Clintrial mapping definition, each PANEL mapping definition corresponds to a panel in a Clintrial study and to a form in an InForm study. The RefName specified in a PANEL mapping definition is the panel name in the Clintrial protocol to which it is mapped.
In the Central Designer software, you can also create PANEL mapping definitions that do not correspond directly to an InForm form. For example, you can create a mapping definition that generates a type 0 panel for non-patient data that will be populated from within the Clintrial software. For more information, see the Central Designer guide Working with Rules and Logical Schemas, in the section CIS mappings for specialized Clintrial panels.
