Item generation
When the CIS software adds an item to its page section definition, it applies the following rules:
- Item order is determined by the value of the IORDER column in the CTSDD.ITEM table. This comes from the order in which items occur in the panel mapping definition created in the Central Designer software
- The Label attribute comes from the value of the DESCRIP column in the CTSDD.ITEM table, if a value exists. This value comes from the Design Note property of the item in the panel item mapping definition created in the Central Designer software. If the DESCRIP value is used, the CIS software removes HTML elements such as
and and formatting characters such as
.If the DESCRIP column is empty, the CIS software uses the value of the ITEM_NAME column in the CTSDD.ITEM table as the Label. This value comes from the RefName property of the item in the panel item mapping definition created in the Central Designer software.
