Master-detail relationship generation
In a page template that includes a cross-panel master-detail relationship, one page section is related to another page section, and the two page sections point to different panels. One panel has a master key item and the other has a detail key item. Clintrial mapping definitions can include master-detail relationships.
When the CIS application identifies a page section involved in a master-detail relationship, it:
- Creates the page template if it does not already exist.
- Creates a context page section in the page template.
- Creates a page section for the master panel and adds it immediately after the context page section.
- Creates a page section for each detail panel and adds them to the page template.
- Adds the page template to the block.
Note: Page keys, master key items, and detail key items must be set up properly, or the detail data in the page may not be displayed. Also, if the CIS application processes a detail panel without a master panel, it does not add a page template with a page section only for the detail panel.
