Subset item generation
Subset items allow the same page section to be added to a page template multiple times based on different values of a subset item. (Each subset value is associated with a different page section instance.)
If the panel for a page section contains a subset item, the CIS software adds the same section to a page template for each unique subset item value specified in the INF_PATHMAP or the AUDIT, UPDATE, or DATA table for the panel.
