Panel audit start date
In the Clintrial software, auditing tracks changes to clinical data and notes associated with clinical data:
- For data entered with the Enter module, study designers can configure the point at which auditing begins, and auditing tracks changes or deletions made to records and notes after the audit start point—Entry, Verification, Validation, Validity, or Merge.
- For EDC data, when you synchronize metadata for an integrated study designed with the Central Designer software to a Clintrial protocol, the CIS software creates new panels if they do not already exist in the protocol. When the CIS software creates Clintrial panels, it automatically sets the audit start point of each panel to Entry.
Note: If you create a panel with the Design module of the Clintrial software to be used in an integrated or hybrid study, you must manually define the panel with an audit start point of Entry. Similarly, do not change the audit start point for panels created by CIS. Creating or changing a panel to an audit start point other than Entry can result in the inability to reinstate data that has been deleted in the InForm software.
