Checklists
A checklist is a type of codelist for which no encoding is performed. The issues surrounding metadata transfer between the Clintrial and InForm environments are the same as with codelists with the following exceptions:
- Checklists are represented within the InForm software as pulldown controls.
- Checklists with the override attribute set can also accept input from users. This is implemented in the InForm software as a radio group with the checklist as the top item of the radio group and a second radio item labeled “Other” that has a textbox associated with it.
