Data Management Rules
The majority of the Oracle Clinical data management rules are built into the functionality of the API. Nonetheless, there are a few data management rules that you must be aware of as you design your front-end application; otherwise, you may generate one or more error messages.
Five data entry modes are valid within the API. The following table describes the appropriate document status for each Log-In and Data Entry mode that the API supports.
| Mode | Status |
Initial Log-In |
RECEIVED |
Key Changes |
RECEIVED, P1 STARTED, P1 COMPLETE |
Update/Browse |
P1 (First Pass) |
RECEIVED, P1 STARTED, P1 COMPLETE only if document is not accessible and the operator is the person who created the document |
Note that the Data Capture API does not support Pass 2. However, in some cases the status does change:
- If you update an RDCM in status PASS 2 STARTED or PASS 2 COMPLETE, the document is opened in UPDATE mode and after a save, the status of the document (RDCM and RDCI) remains unchanged.
- However, if you update an RDCM in status PASS 2 PENDING, then after a save, the RDCM status changes to PASS 2 COMPLETE. If all RDCMs in the RDCI are PASS 2 COMPLETE, then the RDCI status is also updated to PASS 2 COMPLETE.
Parent topic: Data Capture API Overview
