A Error Messages
This section lists the error messages that may be generated when a function is called. To retrieve error messages, call the GetError function.
- -1: [Text varies, according to the particular error]
- Severity: ERR
- 284800: Function not applicable in this mode
- Severity: ERR
- 284900: User does not have the privilege to call function in the current mode
- Severity: ERR
- 285000: Function called out of sequence.
- Severity: ERR
- 285700: An open database connection already exists. Use DisconnectOCL to close the connection.
- Severity: ERR
- 285900: No current OCL database connection open. Use ConnectOCL to connect to OCL database.
- Severity: ERR
- 286000: Cannot disconnect while changes are pending for RDCI/RDCM work.
- Severity: ERR
- 286100: RDCM with this received_dcm_id does not exist.
- Severity: ERR
- 286200: Status of Received DCM with this received_dcm_id is incompatible with data entry mode.
- Severity: ERR
- 286300: Locking mode incompatible with data entry mode.
- Severity: ERR
- 286500: Study is not enabled for data entry.
- Severity: ERR
- 286600: Audit reason required and not provided.
- Severity: ERR
- 286700: Cannot locate the corresponding DCM question in the internal OCL buffers for the DCM question ID passed.
- Severity: ERR
- 286800: No response in the internal buffers for the question.
- Severity: ERR
- 286900: No existing univariate discrepancy for the question.
- Severity: ERR
- 287000: DCM question and DCM question group combination does not exist in DCM.
- Severity: ERR
- 287100: DCM question group does not exist in DCM.
- Severity: ERR
- 287200: Cannot insert repeats in browse mode.
- Severity: ERR
- 287300: Invalid DCM question group ID passed.
- Severity: ERR
- 287400: Cannot insert repeat for a non-repeating question group.
- Severity: ERR
- 287500: Inserting repeat will introduce a null repeat in the middle.
- Severity: ERR
- 287600: Cannot insert for repeating defaults when repeat is less than the maximum repeats for DCM question group.
- Severity: ERR
- 287700: The repeat exceeds the maximum repeats expected for DCM question group.
- Severity: ERR
- 287800: Cannot delete repeats in browse mode.
- Severity: ERR
- 287900: Cannot delete repeat for a non-repeating question group.
- Severity: ERR
- 288000: Repeat sn does not exist for DCM question group.
- Severity: ERR
- 288100: Cannot delete for repeating defaults when repeat is less than the maximum repeats for DCM question group.
- Severity: ERR
- 288300: The API RDCI record is not locked.
- Severity: ERR
- 288400: The completion flag is not compatible with the data entry mode.
- Severity: ERR
- 288500: Write responses called but no changes pending.
- Severity: WRN
- 288600: Blank repeats exist.
- Severity: ERR
- 288700: Mandatory field missing.
- Severity: ERR
- 288800: Cannot set actual event when RDCI is locked.
- Severity: ERR
- 288900: Cannot enroll a patient when RDCI is locked.
- Severity: ERR
- 289000: Cannot set page status when RDCI is locked.
- Severity: ERR
- 289100: Unable to find the RDCI to which page belongs: \0.
- Severity: ERR
- 289200: Unable to lock the RDCI to which page belongs.
- Severity: ERR
- 289300: 'Unknown' page status can only be changed to 'Missing' or 'Present'.
- Severity: ERR
- 289400: The page status cannot be manually changed to a system status.
- Severity: ERR
- 289500: A system page status cannot be manually changed.
- Severity: ERR
- 289800: This document already exists in the database.
- Severity: ERR
- 289900: Document number not derived.
- Severity: ERR
- 289000: Duplicate Received DCI found with the same keys in document number: \0.
- Severity: ERR
- 289100: Duplicate Received DCM found within this Received DCI.
- Severity: ERR
- 289200: Duplicate Received DCM found in document number: \0.
- Severity: ERR
- 289300: Current record is not complete: Operation was not successful.
- Severity: ERR
- 289500: This site/investigator pair is invalid for study.
- Severity: ERR
- 289600: Invalid investigator.
- Severity: ERR
- 289700: Invalid site.
- Severity: ERR
- 289800: Patient position is frozen.
- Severity: ERR
- 289900: Patient not enrolled for study.
- Severity: WRN
- 291000: Patient position is invalid.
- Severity: ERR
- 291100: Patient is not associated with a valid site (active site/site role).
- Severity: WRN
- 291200: DCI is inactive or invalid.
- Severity: ERR
- 291300: [error message returned by OCL_CLIENT_PACK. Validate document]
- Severity: ERR
- 291400: Clinical planned event is invalid for the current study.
- Severity: ERR
- 291500: Subevent not found: actual event will be created once you save.
- Severity: WRN
- 291600: Invalid lab.
- Severity: ERR
- 291700: Discrete value does not exist or is inactive.
- Severity: ERR
- 291800: Discrete value could not be validated.
- Severity: ERR
- 291900: Value must be Y or N.
- Severity: ERR
- 292000: Blank flag must be entered.
- Severity: ERR
- 292100: Clinical planned event name must be entered.
- Severity: ERR
- 292200: Patient must be entered.
- Severity: ERR
- 292300: DCI name must be entered.
- Severity: ERR
- 292400: Site is required.
- Severity: ERR
- 292500: Clinical planned event name is required.
- Severity: ERR
- 292600: Patient is required.
- Severity: ERR
- 292700: DCI is required.
- Severity: ERR
- 292800: DCI date must be entered.
- Severity: ERR
- 292900: Error soft deleting actual event.
- Severity: ERR
- 293000: Subevent number must be entered.
- Severity: ERR
- 293300: DCM time must be entered.
- Severity: ERR
- 293400: Qualifying value must be entered.
- Severity: ERR
- 293500: Cannot set to N (not blank) when Received DCI is blank.
- Severity: ERR
- 293600: Too many actual events correspond to this subevent #.
- Severity: ERR
- 293700: DCM date must be entered.
- Severity: ERR
- 293800: You are working with a data locked record and have privileged update.
- Severity: WRN
- 294000: An error occurred while soft-deleting the responses.
- Severity: ERR
- 294200: An error occurred while processing the Received DCI structure and updating the PATIENT_DM_TRACKING table.
- Severity: ERR
- 294300: An error occurred while processing the Received DCM structure and updating the received DCI.
- Severity: ERR
- 294500: Document number already exists with patient from another location.
- Severity: ERR
- 294600: Document found in different study. Change study to access.
- Severity: ERR
- 294700: Received DCI is protected because at least one of its received DCMs is locked.
- Severity: WRN
- 294800: An error occurred while in the Rxc_Login_Pack SoftDeleteAll received DCMs function.
- Severity: ERR
- 294900: Site is currently inactive.
- Severity: WRN
- 295000: Investigator is currently inactive.
- Severity: WRN
- 295100: Site/investigator pair is not current in study.
- Severity: WRN
- 295200: Too many rows found in NON_EXPECTED_DCMS table.
- Severity: ERR
- 295300: An error occurred querying DVGs for an RDCM.
- Severity: ERR
- 295400: An error occurred validating the clinical planned event.
- Severity: ERR
- 295800: Problem retrieving from the actual event sequence.
- Severity: ERR
- 296100: Too many DCI IDs for DCI short name.
- Severity: ERR
- 296200: Too many DVGs match DVG ID.
- Severity: ERR
- 296300: Too many labs with same name.
- Severity: ERR
- 296600: Cannot preserve lock when performing a rollback.
- Severity: ERR
- 296700: Unable to lock RDCI.
- Severity: ERR
- 297000: Null or invalid input parameters provided.
- Severity: ERR
- 297100: Changes pending.
- Severity: ERR
- 297200: Invalid execution context.
- Severity: ERR
- 297300: Procedure ID is required for SINGLE execution context.
- Severity: ERR
- 297400: Procedure version is required for SINGLE execution context.
- Severity: ERR
- 297500: Invalid Procedure (nonexistent, retired or pre-V3.1-style).
- Severity: ERR
- 297600: Procedure is not active or needs to be regenerated.
- Severity: WRN
- 297700: Procedure is not compiled.
- Severity: WRN
- 297800: DCM ID is required for ON-LINE/DCM execution context.
- Severity: ERR
- 297900: DCM ID does not apply for ON-LINE execution context.
- Severity: ERR
- 298000: DCM ID does not apply for SINGLE execution context.
- Severity: ERR
- 298100: Procedure ID and version must be -1 for ON-LINE and ON-LINE/DCM execution contexts.
- Severity: ERR
- 298200: Mandatory patient position ID is missing.
- Severity: ERR
- 298300: Invalid preserve lock value.
- Severity: ERR
- 298400: Mandatory clinical study ID is missing.
- Severity: ERR
- 298500: Mandatory clinical study version ID is missing.
- Severity: ERR
- 298600: Invalid mode value.
- Severity: ERR
- 298700: Invalid debug flag value.
- Severity: ERR
- 298800: Mandatory execution context is missing.
- Severity: ERR
- 299000: Only browse mode can be performed on a frozen study.
- Severity: ERR
- 299100: No data has been entered for this RDCM.
- Severity: ERR
- 299200: RDCI status is incompatible with querying the record in first-pass entry mode.
- Severity: ERR
- 299300: RDCI is accessible. You can query only inaccessible documents in first-pass entry mode.
- Severity: ERR
- 299400: Operator comment in browse is disabled. You cannot fetch the document in locking mode.
- Severity: ERR
- 299500: RDCI is inaccessible. You can query only accessible documents in browse mode.
- Severity: ERR
- 299600: Owning location of the patient is different from that of the database.
- Severity: ERR
- 299700: The data entered for this received DCI will be deleted.
- Severity: WRN
- 299800: Date cannot exceed today's date.
- Severity: ERR
- 299900: Cannot proceed when blank flag is set to Y.
- Severity: ERR
- 300100: Only the user who performed Pass 1 Entry can perform data entry task.
- Severity: ERR
- 300200: This patient is frozen.
- Severity: ERR
- 300300: This Received DCI is data locked.
- Severity: ERR
- 300500: First pass entry cannot be performed on an accessible RDCM.
- Severity: ERR
- 300600: RDCI status not compatible with the mode.
- Severity: ERR
- 300700: Patient is frozen. The RDCI record will behave as if it were fetched in non-locking mode.
- Severity: WRN
- 300800: Data on this RDCI is locked. The RDCI record will behave as if it were fetched in non-locking mode.
- Severity: WRN
- 300900: No update allowed to the RDCI buffer.
- Severity: ERR
- 301200: No changes to save.
- Severity: WRN
- 301300: Invalid clinical study.
- Severity: ERR
- 301400: The clinical study is not live.
- Severity: ERR
- 301500: Data entry is not enabled for the clinical study.
- Severity: ERR
- 301600: Clinical study does not exist in the current location.
- Severity: ERR
- 301700: No study state for the clinical study.
- Severity: ERR
- 301800: No study access account exists for the study.
- Severity: ERR
- 301900: Record validation failed.
- Severity: ERR
- 302000: User is not authorized to access the study.
- Severity: ERR
- 302100: Validation of study failure.
- Severity: ERR
- 302200: Mode should be OCL_PROD or OCL_TEST.
- Severity: ERR
- 302300: Cannot disconnect while changes are pending for responses work.
- Severity: ERR
- 302400: Zero rows updated.
- Severity: WRN
- 302500: Invalid page status.
- Severity: ERR
- 302600: Cannot delete when repeat sn is greater than the number of repeats currently existing for the question group.
- Severity: ERR
- 302700: No existing manual discrepancy for the question.
- Severity: ERR
- 302800: Invalid discrepancy review status code.
- Severity: ERR
- 302900: Invalid discrepancy resolution type code.
- Severity: ERR
- 303000: Resolution type code cannot be null for RESOLVED review status.
- Severity: ERR
- 303100: Resolution type code should be null if review status is not RESOLVED.
- Severity: ERR
- 303200: Invalid manual discrepancy type.
- Severity: ERRCause: An invalid manual discrepancy type was entered.
- 303300: Changes are pending for RDCI/RDCM work.
- Severity: ERR
- 303400: Changes are pending for responses work.
- Severity: ERR
- 303500: Document contains empty repeats.
- Severity: ERR
- 303600: Invalid patient.
- Severity: ERR
- 303700: Patient does not belong to the current location.
- Severity: ERR
- 303800: Cannot find location_code in the reference codelist for the current connection.
- Severity: ERR
- 303900: Too many current documents with this number.
- Severity: ERR
- 304000: Too many patients with this name.
- Severity: ERR
- 304100: Too many occurrences of this CPE name exist.
- Severity: ERR
- 304200: Too many sites with this name.
- Severity: ERR
- 304300: Too many investigators.
- Severity: ERR
- 304400: No procedures qualify for execution.
- Severity: WRN
- 304500: Cannot preserve lock as the Received DCI is not locked.
- Severity: ERR
- 304600: Function does not exist.
- Severity: ERR
- 304700: Privilege does not exist.
- Severity: ERR
- 304800: User is not authorized to call this function.
- Severity: ERR
- 304900: User has been granted too many roles: exceeds the maximum allowed.
- Severity: WRN
- 305000: Too many messages.
- Severity: WRN
- 305600: Invalid DCI date.
- Severity: ERR
- 305700: Invalid DCI time.
- Severity: ERR
- 305800: Invalid DCM date.
- Severity: ERR
- 305900: Invalid DCM time.
- Severity: ERR
- 306100: Changes pending that have not been processed.
- Severity: ERR
- 306200: RDCI record being deleted does not exist in the database.
- Severity: ERR
- 306300: Received DCI is inactive or invalid.
- Severity: ERR
- 306400: Too many current actual events.
- Severity: ERR
- 306500: Unable to release lock.
- Severity: ERR
- 306600: This received DCM is locked.
- Severity: ERR
- 306700: Cannot set RDCI time when name is not set.
- Severity: ERR
- 306800: Invalid audit reason.
- Severity: ERR
- 306900: No update allowed to the RDCM buffer.
- Severity: ERR
- 307000: Cannot call this function if you have not locked the record.
- Severity: ERR
- 307100: Investigator is required.
- Severity: ERR
- 307200: DCI Time is required.
- Severity: ERR
- 307400: Please use the patient enrollment form to specify which DCI Book to use to maintain the page tracking information.
- Severity: WRN
- 307600: Can not log-in data for a patient that is not associated with a book in a study with no default DCI book.
- Severity: ERR
- 308200: The DCI book assigned to this patient is not active. Can not use a DCI book that is not active to log data in a production environment.
- Severity: ERR
- 308500: The current DCI book is Retired and the environment is Test.
- Severity: ERR
- 308600: Record changed by another user.
- Severity: ERR
- 308700: Cannot set RDCI time until RDCI short name is set.
- Severity: ERR
- 308800: DCI short name is not applicable.
- Severity: ERR
- 308900: DCI short name is not updateable.
- Severity: ERR
- 309000: Document number is not updateable.
- Severity: ERR
- 309100: Document number is not updateable.
- Severity: ERR
- 309200: Patient is not applicable.
- Severity: ERR
- 309300: Patient is not updateable.
- Severity: ERR
- 309400: Date is not applicable.
- Severity: ERR
- 309500: Date is not updateable.
- Severity: ERR
- 309600: Time is not applicable.
- Severity: ERR
- 309700: Time is not updateable.
- Severity: ERR
- 309800: Visit name is not applicable.
- Severity: ERR
- 309900: Visit name is not updateable.
- Severity: ERR
- 310000: Subevent number is not applicable.
- Severity: ERR
- 310100: Subevent number is not updateable.
- Severity: ERR
- 310200: Site is not applicable.
- Severity: ERR
- 310300: Site is not updateable.
- Severity: ERR
- 310400: Investigator is not applicable.
- Severity: ERR
- 310500: Investigator is not updateable.
- Severity: ERR
- 310600: Blank flag is not applicable.
- Severity: ERR
- 310700: Blank flag is not updateable.
- Severity: ERR
- 310800: Comment is not applicable.
- Severity: ERR
- 310900: Comment is not updateable.
- Severity: ERR
- 311000: Qualifying value is not applicable.
- Severity: ERR
- 311100: Qualifying value is not updateable.
- Severity: ERR
- 311200: Lab is not applicable.
- Severity: ERR
- 311300: Lab is not updateable.
- Severity: ERR
- 311400: Data comment is not applicable.
- Severity: ERR
- 311500: Data comment is not updateable.
- Severity: ERR
- 311600: DCI document number can not be updated to null.
- Severity: ERR
- 311700: Document number must not have any lower case letters.
- Severity: ERR
- 311800: Patient not assigned to this site.
- Severity: WRN
- 312200: Can not delete Received DCI because it is data locked.
- Severity: ERR
- 312500: Can not update repeating defaults when repeat sn is less than the maximum repeats expected for DCM question group.
- Severity: ERR
- 313600: You have privileged update and have deleted repeating default when repeat sn is less than the maximum repeats for DCM question group.
- Severity: WRN
- 313800: User is not authorized to call ExecuteMultivariate (not granted RXCLIN_MOD privilege)
- Severity: ERR
- 314800: Received DCI is accessible; please use Key Changes to change Blank Flag
- Severity: ERR
- 314900: Received DCM is accessible; please use Key Changes to change Blank Flag
- Severity: ERR
- 315000: Some received DCMs are accessible; please use Key Changes to change Blank Flag
- Severity: ERR
- 315100: Responses exist for this RDCI. Changing the Blank Flag to 'Y' will cause them to be irrevocably deleted
- Severity: WRN
- 315200: Responses exist for this RDCM. Changing the Blank Flag to 'Y' will cause them to be irrevocably deleted
- Severity: WRN
- 315500: RDCI is not protected because at least one of its RDCMs is locked and you have privileged update.
- Severity: WRN
- 317400: Another session is connected. Cannot switch database modes.
- Severity: ERR
- 317800: Cannot delete accessible Received DCI in Initial Login Mode.
- Severity: ERR
- 345400: Qualifying value can only be changed to the default value defined at the DCI module.
- Severity: ERR
- 659700: No default audit reason.
- Severity: ERR
- 659800: More than one default audit reason found.
- Severity: ERR
- 660000: Cannot use system generated audit reason.
- Severity: ERR
- 685900: Audit comment for Deletion of Repeat cannot have more than 158 bytes.
- Severity: ERR
- 743300: Cannot delete Received DCI without a valid audit reason.
- Severity: ERR
- 970100: The following sequence(s) is approaching itx maximum value. Reset each listed sequence to an unused lower value.
- Severity: ERR
- 992100: All other parameters except the resolution text in the discrepancy structure will be ignored.
- Severity: WRN
- 992300: Unable to get existing discrepancy information from the database.
- Severity: ERR
