Interface Procedures to Be Maintained by the Customer
The following procedures maintain referential integrity between Oracle Clinical and another customer application. You must maintain independence between Oracle-supplied code and customer applications, while maintaining referential integrity and complying with site support agreement rules. These requirements are provided for by a set of database procedures that can be maintained and used either by Oracle or by the customer.
The following sections list each test or update separately; in the actual implementation some are merged. Local procedures may differ, but the parameters and procedure names are fixed.
- Prevent Study Deletion
- Delete Interface Records
- Delete Local Records
- Prevent Region Deletion
- Update Region Code
- Treatment Pattern Deletion Check
- Treatment Assignment Deletion Check
- Get the Value of a Study Site Code
- Validate a Study Site Code
- Check That a Study Site Code Can Be Changed
Parent topic: Interface Tables and Views
Prevents a study from being deleted by checking in related tables in non-Oracle Clinical applications before a clinical study is deleted. Only a return value of OK allows the study to be deleted; anything else means failure.
LocalStudyDeletion.LocalDeletionOKParam = nStudyId in number(10)
vReturnMsg out Char(60)
Parent topic: Interface Procedures to Be Maintained by the Customer
Deletes records from the OCL tables used by Oracle Clinical. A return value of DONE means that everything worked correctly; anything else means failure.
LocalStudyDeletion.DeleteOCLRecordsParam = nStudyId in number(10)
Deletes clinical study-related records from non-Oracle Clinical tables when a clinical study is deleted. A return value of DONE means that everything worked correctly; anything else means failure.
LocalStudyDeletion.DeletelocalRecordsParam = nStudyId in number(10)
Checks if a region can be deleted based on local usage. A return value of DONE means that everything worked correctly; anything else means failure.
LocalRegionUpdateDeletion.LocalRegDeletionOKParam = nRegionId in number(10)
vRegionCode in char(7)
Update Region Code
Applies a cascade update when a region code is changed.
LocalRegionUpdateDeletion.LocalRegionCascadeUpdateParam = vOldRegionCode in varchar2(7)
vNewRegionCode in varchar2(7)
vReturnMsg out varchar2(60)
Checks if a treatment pattern can be deleted based on local usage. A return value of DONE means that everything worked correctly; anything else means failure.
LocalTreatPattDeletion.LocalTreatPattDeletionParam = nTreatPattId in number(10)
vReturnMsg out char(60)
Checks if a treatment assignment can be deleted based on local usage. A return value of DONE means everything worked correctly; anything else means failure.
LocalTreatAssnDeletion.LocalTreatAssnDeletionOKParam = nTreatAssNum in number(10)
vStartCode in char(10)
vreturnMsg out char(60)
Supplies the value of a STUDY_SITE code.
LocalStudySite.GetStudySiteParam = vStudySite in varchar2 (10)
vSiteCode in varchar2(10)
nSiteId in number(10)
vTestProd in varchar2(1)
vReturnStudySite out varchar2(10)
Validates a STUDY_SITE code. A return value of OK means the value is acceptable.
LocalStudySite.ValidateStudySiteParam = vStudyCode in varchar2(10)
vStudySite in varchar2(10)
Checks whether a STUDY_SITE code can be changed.
- LocalStudySite.ChangeStudySite
- Param = vStudyCode in varchar2(10)
vTestProd in varchar2 1)
vOldStudySite in varchar2(10)
vNewStudySite in varchar2(10)
