Adding, Removing, and Editing a DCF's Discrepancies
To add and remove a DCF's discrepancies, select a DCF and click the Discrepancies button to open the Maintain DCFs window. Opening the Maintain DCFs window in this manner displays only the discrepancies associated with the selected DCF. You can add and remove discrepancies, maintain question and resolution text, and change the current discrepancy.
