Removing a Discrepancy from a DCF
You can remove a discrepancy from a DCF by selecting the discrepancy and clicking the Remove button. If this button is grayed out, the current status of the DCF—either FINAL or SENT—does not permit removing the discrepancy.
If you remove a discrepancy from a DCF that has not yet been SENT, the discrepancy is deleted from the DCF. If the DCF has progressed beyond the SENT status, the discrepancy is still visible in the report, but its status is RELEASED.
When you remove a discrepancy from a DCF, either before or after the DCF reaches a status of FINAL or SENT, it is available for inclusion in other DCFs. Removing or releasing the discrepancy from a DCF does not change its review status.
