Changing the DCF Status from the Maintain DCFs Window
When you change the DCF Status from the Maintain Data Clarification Forms window, you are restricted to entering one of the following:
  • the next mandatory status
  • a status between the current status and the next mandatory status
See codelist DCF OPTIONAL STATUS CODES to determine which status values are optional. By default, any values not listed in optional status codes are required and should exist in the DCF Status Codes Codelist.
You cannot change DCF status from the Maintain DCFs window if you have used the REPRINT print status and the status is SENT, RECEIVED, INCOMPLETE, or PART RECEIVED.
You cannot change discrepancy status back to UNREVIEWED.
