Changing the Display of Discrepancy Information
You can control the order in which the discrepancy information is displayed during this session. To change the display:
  1. In the multi-record view (only) of the Maintain Discrepancy Database window, click the Change Layout button.
    The Change Layout window opens (see Filtering Discrepancy Information). The Details section lists all the items in the Maintain Discrepancy Database window.
  2. Use the Left arrow to move the fields you select into the Master, or upper, section of the window in multi-record view. The system populates the fields in the Master section with values from the discrepancy that is highlighted in the lower section of the window. You can see all the fields in the Master section (up to eight fields) without scrolling.
    Use the Right arrow to move fields from the Master section into the Detail, or lower, section of the window.
  3. Use the Up and Down arrows to adjust the display order of the items. The topmost item in either the Master or Details list appears leftmost in the appropriate section of the Maintain Discrepancy Database window. The second item displayed in the Details section appears second to the left, and so on.
  4. Click OK to save your changes or click Back to return without saving your changes.
    You return to the Maintain Discrepancy Database window. If you clicked OK, the system refreshes the view of the window to reflect the changes you made.
