Clearing a CDS
If your criteria returned few target records or is not inclusive enough, it may make sense to clear it and start over with the criteria specification. This is possible only when the MCS status is CREATED. To clear the CDS, from the Special menu, select Clear CDS. This action clears all records from the CDS and changes the status of the MCS back to Specified. You can then edit the specification and recreate the CDS.
Use the Audit Comment field to document the reason for this change. The system adds the comment to each record in the CDS.
