To Reorder the Display and Processing Order:
  1. Click the Reorder button or enter keyboard combination Ctrl+Shift+F11.
  2. Select the field you want to serve as the primary sort field.
  3. Use the Up or Down arrow to move that field to the top of the list.
  4. Repeat Steps 2 and 3 for the other fields.
  5. Choose either Ascending or Descending sort order for each field.
  6. Click OK. Oracle Clinical rearranges the records and you return to the CDS window.
