Group-Updating Review Status
This Group Function allows a user to change the review status code for multiple discrepancies. You must assign the same status to all the discrepancies you select. If you select the status Irresolvable, you must also apply the same resolution code to all selected discrepancies. To update the review status of a group of discrepancies:
Parent topic: Managing Discrepancies
