Navigation and Format
You can run the graphic PDR in either Portrait or Landscape format. Launch the Report Submission window for your selected format: from the Conduct menu, select Conduct Reports, then select Data Validation, and choose Graphic Patient Data Report (portrait) or Graphic Patient Data Report (landscape). The format choice affects the non-CRF sections of the report only. Each CRF is presented in the format in which it was designed. This makes it possible, in the case of CRFs with landscape layouts, to have a report with the Audit History Report in portrait layout, and the CRFs in landscape.
You can also run the Audit History Report, which prints only that portion of the PDR.
Parent topic: Graphic Patient Data Report
