Querying Within the Filter Limitations
If you want to query on a value represented in the lower panel of the Maintain Discrepancy Database window, click F7, or from the Query menu, select Enter Query. The system displays the Maintain Discrepancy Database window in single-record view with the values of the filter items supplied. These values will be included in any query you enter.
