Viewing Univariate Discrepancies' Related Discrepancies
To view other discrepancies associated with the same question, select the discrepancy in the Maintain Discrepancy Database window and click the Details button. A dialog box opens. The bottom section of the Response Details window contains a list of discrepancies associated with the same question, with the current discrepancy listed at the top. There is information on the related discrepancies' type, category, and review status. If the discrepancy is a multivariate one, you see the name of the Procedure, and the number of the Detail (code) within the Procedure that generated the discrepancy.
The top section displays much of the same information as the Maintain Discrepancy Database window, but also shows Event Time, Investigator Data Comment, Data Change Reason, and Audit Comment.
If you have the necessary database privileges, you can access Data Entry by selecting Update Patient Data from the Special menu to modify the responses (see Browse and Update Patient Data). See Discrepancy Types for more information on univariate discrepancies.
If you have Oracle Clinical Release 3.1-style Procedures, you can prevent processing variables (questions) with univariate errors. (See Validation and Derivation Procedures in the Oracle Clinical Creating a Study manual.)
Parent topic: Using the Maintain Discrepancy Database Window
