Univariate Validation
As the cursor is about to leave a response field, Oracle Clinical validates the data entered in the field, checking for each of the following criteria:
Value is entered where response has been defined as mandatory.
Length of value is less than or equal to the definition.
Decimal precision for numeric fields is less than or equal to the definition.
Data type (character, number, date) is correct.
Dates are at least as complete as the date type requires.
Value for a DCM question with a discrete value group (DVG), including an external DVG (thesaurus), is valid.
Value falls within the upper and lower bounds, if bounds exist, for numeric, date, or time fields.
Parent topic: Validating Data Entry
