Adding View Definitions
You can add view definitions to a copy group by selecting Copy Groups from the Definition menu, then choosing Copy Groups, clicking the Copy Groups Details button, and the View Definitions button.
When a view definition is used, the view definition and all of its components are copied. The name must not be present in the target domain. If the view definition references a library view template, only the view definition is copied: the template remains a reference to the library template. If the source of the view definition is a study, then the view template is copied as well. The mapping of the view definition to the DCM in the copy group is used to ensure that the copied view definition references the equivalent DCM and DCM Questions in the target.
