Completing Easy Study Design
To make your study operational you can complete these tasks from within the standard design modules:
Assign the study to one or more study sites. See Assigning Sites to a Study.
Assign an Investigator to each of your study sites. See Assigning Investigators to Study Sites.
Allocate patient positions to the study sites. See Assigning Patient Positions to Sites.
To refine the definitions of the objects you create in Easy Study Design, you can use the standard study design forms.
Parent topic: Easy Study Design
