Enabling DCI Forms
You enable the definition of DCI Forms and data entry using DCI Forms at the study level by logging in to Oracle Clinical and opening the Clinical Study States form: Navigate to Conduct, Security, and then Clinical Study States. Query and select your study, then select its DCI Forms Definition Enabled? and DCI Forms Entry Enabled? boxes. Save your work and exit.
You must download the latest version of the Oracle Clinical PDF Plugin from My Oracle Support, as described in the Oracle Clinical Installation Guide, to use the Annotated Layout feature.
You can enable the definition of DCI Forms by default for all studies on a local database through a local database setting. If you do this, when you create a study through Easy Study Design, you do not have to enable the study in the Clinical Study States window. From the Admin menu, select DCI Form Local Database Settings, then DCI Form Definition. Set DCI Forms Definition Enabled to Yes. See the Oracle Clinical Administrator's Guide for a description of local database configuration.
Parent topic: Creating Graphic Layouts
