V3.1-Style and Pre-V3.1-Style Procedures
Oracle Clinical V3.1 introduced a new style of Procedure, with functional enhancements. V3.1-style Procedures consist of static packages in the database rather than anonymous PL/SQL blocks, eliminating the need to parse a Procedure each time it is executed, for greater efficiency and speed.
You can continue to run existing pre-V3.1-style Procedures in V3.2 and later releases with their current functionality, or you can explicitly convert them to the V3.1 style for enhanced performance. After converting a Procedure to the V3.1 style, you can modify it to take advantage of the additional functionality. You can create new Procedures in either the newer V3.1 style (the default) or the old (pre-V3.1) style.
For more information, see:
- V3.1-Style Procedure Enhancements
- Converting to the V3.1 Style
- Creating a New Pre-V3.1-Style Procedure
Parent topic: Validation and Derivation Procedures
Increased speed of execution
Possible to add custom code in more locations in the code without editing generated PL/SQL
Separate Report?, Test Not Null?, Continue If Discrepancy? boxes and other settings for each variable as it is associated with each detail, making it possible to include more details in a single Procedure
Ability to prevent processing Question responses with current univariate discrepancies, and a multipick list of values to select which univariate discrepancies prevent processing in each detail
Option to choose which detail to process next, if Oracle Clinical finds a discrepancy and the Continue If Discrepancy? box is selected
Embedded data values in discrepancy messages to improve context sensitivity
Additional event order processing choices based on:
the leading fields DCM Date and Time, plus Visit and Subevent Numbers
acceptance of manually coded processing order based on trailing fields, usually Qualifying_Value and/or Repeat_SN
Single repeat only option for repeating Question Groups
Capacity to correlate Questions with the previous or next event, as well as the actual event
A new standard variable,
question
$exc_val
, which provides the EXCEPTION_VALUE_TEXT field value for all Question Group Questions -
An extended multipick list of values for variables, including Question Group Cursor key fields, Patient Position Cursor fields, internal Procedure variables, and DVG information, customized according to the field from which it is invoked
Optional re-execution of Procedures for patient records affected by lab range and lab range subset changes made since the last batch validation
Parent topic: V3.1-Style and Pre-V3.1-Style Procedures
When converting a pre-V3.1-style Procedure to the V3.1 style, it is helpful to understand what Oracle Clinical does internally to accomplish the conversion:
Populates the data structure, Variable Settings, for each detail, as appropriate.
Generates the Procedure in V3.1 style, as a packaged object. This step occurs only if the Procedure being converted has been successfully generated; if not, you are prompted to generate the Procedure after conversion. Oracle Clinical will not generate Global Library Procedures.
Switches the Ver 3.1 Style? box to selected if the conversion was successful.
Oracle Clinical saves the pre-V3.1 version of the Procedure, and reverts to it if problems are encountered in conversion.
Oracle Clinical preserves all current discrepancies associated with a Procedure when you convert the Procedure.
To convert a single existing pre-V3.1-style Procedure to the V3.1 style:
For more information , see:
Conversion Example
Original, pre-V3.1-style Procedure Pre-Details custom code:
... SELECT DATA_COMMENT_TEXT INTO COMMENT_VAR FROM RESPONSES WHERE RESPONSE_ID = A.QUESTION1$RESP_ID AND RESPONSE_TS = A.QUESTION1$ENT_TS; ...
The code after conversion by Oracle Clinical (the same, in this case; if the code had included the variables PATIENTS_REC., TEST_OR_PROD, or BATCH_START_TS, they would have been renamed RXCPDSTD.PATIENTS_REC., RXCPDSTD.V_MODE, or RXCPDSTD.V_CURRENT_BATCH_TS, respectively):
The code after you have made the required edits to account for test and production tables' references:
IF RXCPDSTD.V_MODE = 'P' THEN /* PRODUCTION RUN*/ ... SELECT DATA_COMMENT_TEXT INTO COMMENT_VAR FROM RESPONSES WHERE RESPONSE_ID = A.QUESTION1$RESP_ID AND RESPONSE_TS = A.QUESTION1$ENT_TS; ... ELSE /* TEST RUN*/ ... SELECT DATA_COMMENT_TEXT INTO COMMENT_VAR FROM RESPONSEST WHERE RESPONSE_ID = A.QUESTION1$RESP_ID AND RESPONSE_TS = A.QUESTION1$ENT_TS; ... END IF;
For a test run, add a "T" to the name of the table to indicate the test table with the same type of data as the production table of the same name. For example, ResponsesT, not Responses.
Parent topic: Converting to the V3.1 Style
The default style for new Procedures from 3.1 on is the 3.1 style. However, you can create a new, pre-V3.1-style Procedure by deselecting the Ver 3.1 Enabled? box for the Procedure in the Procedure Definitions window.
You can do this only when you first create the Procedure definition, before saving it.
