Create the Repository Creation Utility
For this task, you need the following database server details:
- Host name
- Port
- Service name
- Password for the SYS account
For instructions, see Oracle® Fusion Middleware Installing Oracle Forms and Reports for Release 12.2.1.4, at https://docs.oracle.com/en/middleware/developer-tools/forms/12.2.1.4/install-fnr/installing-and-configuring-oracle-forms1.html#GUID-EBBA8709-F563-469C-9D2F-F308AF4E60C5. In this link, read the first step as "Run FMW_HOME/oracle_common/bin/rcu.bat."
You can accept most default values, with the exception noted below.
Select Components
- Select the option Oracle Platform Security Services.
- Enter the prefix name for the domains in the following format:
servernameFR
Schema Password
- Provide a schema password and make note of the schema name and password because they are required to configure the FRDomain.
Parent topic: Install and Configure the Oracle Application Tier
