Configure the FRDomain
For instructions, see Oracle® Fusion Middleware Installing Oracle Forms and Reports for Release 12.2.1.4, at https://docs.oracle.com/en/middleware/developer-tools/forms/12.2.1.4/install-fnr/installing-and-configuring-oracle-forms1.html#GUID-E3EC8981-780D-4D15-AA01-1FF91CDDCF59.
Doc bug 28905683: Added the note.
Ignore the warning "CFGFWK-40326" that appears in the Configuration Summary screen as it is not related to the Oracle Forms and Report configuration.Make sure you type FRDomain (case-sensitive) in the desired domain home path.
When configuring the FRDomain, it is recommended to use the default port 7001 for Admin Server and 9001 or 9002 for managed servers (WLS_FORMS and WLS_REPORTS).
You can accept most default values, with the exception noted below.
Doc bug 28905705: Added the following sentence.
After completing the FRDomain configuration, follow instructions in Run ohs_updateInstances.
Templates
- Select the check box for the following templates:
- Oracle Forms [forms]
- Oracle Reports Application [reports]
- Oracle Enterprise manager [em]
- Oracle HTTP Server (Collocated) [ohs]
- Oracle Reports Tools [ReportsToolsComponent]
- Oracle Reports Server [ReportsServerComponent]
- Oracle Reports Bridge [ReportsBridgeComponent]
- Oracle JRF [oracle_common]
- Weblogic Coherence Cluster Extension [wlserver]
Add Administrator Account - Provide a password for the WebLogic user account and make note of this password because it is required to install Oracle Clinical and/or Oracle Thesaurus Management System.
Domain Mode and JDK - Select the Production option under Domain Mode.
- Provide the Repository Creation Utility schema name that you defined in Create the Repository Creation Utility and add _STB to this name. For example, if the schema name you defined was OCRDCDEV, provide OCRDCDEV_STB.
- Provide the schema password that you defined in Create the Repository Creation Utility.
- Click Get RCU Configuration to continue.
Advanced Configuration - Select all check boxes.
Administration Server - Select the Enable SSL check box.
Node Manager - Define the Node Manager username and password and make note of them because they are required to install Oracle Clinical and/or Oracle Thesaurus Management System.
Managed Servers - Select the Enable SSL check box for all managed servers.
Assign Servers to Machines - Move AdminServer from the Servers list to the Machines list.
- Click Add to add the OHS component.
- For System Component, specify ohs1.
- For the Component Type, select OHS.
It is recommended to use the standard HTTP/HTTPS ports 80 or 443. If you plan to use other ports, these need to be modified accordingly during the installation process.- For Listen Address, specify the machine name, including the domain.
- Change the Listen Port value to 80.
- Change the SSL Listen Port value to 443.
- Copy the URL from the Plain field and paste it in the SSL field.
- In the SSL field, change http to https, and add the SSL port if the non-standard port 443 is used.
- Select the SSL as the default option.
Assign System Components - Move ohs1 from the System Component list to the Machines list.
Doc bug 28905705: Added this section.
Perform the following steps:
Parent topic: Configure the FRDomain
