Configuring Custom Review Types
To define custom review types and the privileges required to perform custom reviews in RDC, use the Installation Reference Codelist CUSTOM REVIEW TYPES.
  • For the Short Value, define the name of the privilege you will assign to users who will perform this type of review, like SAFEREV or DMREV. The short name should have 8 characters at most.
  • For the Long Value, define the name of a review type, like Safety Review or DM Review. The long value appears with review metrics in RDC summary reports and elsewhere in the RDC user interface, including the Search pane and the Assign Review Status dialog. For more information, see "Add Custom Review Types" in the Oracle Clinical Remote Data Capture Onsite Administrator's Guide.
After you activate and save these codelist values, you can assign the privileges to individual users from the Users and Roles menu under Study Security and Site Security. In RDC, users who are assigned a custom review privilege will be able to update the CRF status for the corresponding review type.
The privilege BROWSE_REVIEW allows an RDC user to view the CRF status for all review types. For more information on privileges, see "Configuring Study and Site Security Privileges" in the Oracle Clinical Remote Data Capture Onsite Administrator's Guide.
