Customizing Flexfields
The Maintain Discrepancy Database window includes two editable fields that have the default labels Flexfield1 and Flexfield2. You can use them to store information you need. You can change their labels, make the fields mandatory if you want, and create a dynamic or static list of values for each field:
- Static List of Values. By default, the fields get their list of values from a database view that references the local reference codelists DISC_FLEX1_VALUES and DISC_FLEX2_VALUES. You can populate these reference codelists to create lists of values for the two fields.
- Dynamic List of Values. Alternatively, you can reprogram the view to
reference another Oracle Clinical table or even an
Oracle table outside Oracle Clinical, such as an
adverse event code maintained in a different Oracle
system. In each field you can display any column
value or concatenation of column values.
The views, DISCREP_FLEX1 and DISCREP_FLEX2, respectively, are created during installation as follows:
create or replace view discrep_flex1 as select ref_codelist_value_short_val VALUE, long_value DESCRIPTION from reference_codelist_values where ref_codelist_name = 'DISC_FLEX1_VALUES' and active_flag='Y';
For more information, see:
Parent topic: Configuring Discrepancy Management
DISC_FLEX1 and DISC_FLEX2
Use these local reference codelists to customize the label for Flexfield1 or Flexfield2, to enable the field, to make the field mandatory or not, and to specify whether or not there is a list of values for the field.
Table 3-7 DISC_FLEX1 and DISC_FLEX2 Settings
| Short Value | Long Values | Description |
Set the long value to |
Set the long value to Y to require users to enter text in this field. Set to N to make the field optional. |
text |
Enter freeform text as the long value. This text becomes the field label in the Discrepancy Database window. |
Parent topic: Customizing Flexfields
If you set LOV_VALIDATE to Y in DISC_FLEX1, you can create a static list of values by entering each allowed value in a row in this codelist. When a user displays the list of values in the Discrepancy Database window, the system displays the short value and description for each row you enter here. (Alternatively, create a dynamic list of values; see Customizing Flexfields.)
The long value is used as the description in the Flexfield1 (or 2) field's list of values. The short value is stored in the FLEX_FIELD1 (or 2) column in the DISCREPANCY_ENTRIES table in the database. The default value has no effect.
Table 3-8 DISC_FLEX1_VALUES and DISC_FLEX2_VALUES Codelists
| Field Name | Description |
Seq |
Determines the order of the values in the list of values for the flexfield. |
Short Value |
Is the stored value when the user selects the row from the list of values. |
Long Value |
Can duplicate the short value; is not displayed in the list of values. |
Active box |
Select the Active check box to have the entry appear in the list of values. |
Default |
Identifies which value is the default value. |
Description |
Provides additional information about the value; the information displays in the list of values. |
Example
To customize Flexfield1 to ask the creator of a manual discrepancy record if the record is finished, and test the response entry against a list of three values, you would set the flexfield1 codelist values to the values in the following two tables, with the three values defined in the second. (Values that differ from the default values are in italics.)
Table 3-9 DISC_FLEX1 Settings to Make a Finished? Prompt
| Seq | Short Value | Long Value | Active | Default | Description |
1 |
ENABLED |
Y |
Selected |
Flexfield1 Displayed |
2 |
REQUIRED |
N |
Selected |
Flexfield1 Required |
3 |
PROMPT |
Finished? |
Selected |
Flexfield1 Prompt |
4 |
LOV_VALIDATE |
Y |
Selected |
Flexfield1 list of values Validate |
Table 3-10 DISC_FLEX1_VALUES Settings for a Finished? List of Values
1 |
Y |
Yes |
Selected |
2 |
N |
No |
Selected |
3 |
U |
Undetermined |
Selected |
Selected |
