Enabling a Study for Replication
A study is available for replication only if its Ready to Repl check box is selected. In addition, only the study-owning location can designate when a study is ready for replication.
To enable a study to be available for replication:
- Navigate to Design, Studies, and then select Clinical Studies.
- Scroll to the right in the window.
- Select the Ready to Repl? check box. See Figure 13-2.
- Click Save.
Figure 13-2 Enabling a Clinical Study for Replication
Parent topic: Using Replication
