Set Up Automatic Startup
It is possible to configure any Windows service to restart itself upon failure. These are standard options available when configuring a Windows service in the context of Windows Services Manager.
However, it is important to understand that Windows Services Manager only monitors the service's JVM process. If the JVM process fails (shuts down), then Windows Services Manager will attempt to restart it. But there are some scenarios where the WebLogic Admin Server or Managed Server may go into an unhealthy or failed state while the JVM is still running. The Windows Service Manager will not know to restart the process in these cases, whereas if the Admin Server and Managed Server had been started using the WebLogic Node Manager, Node Manager would recognize such a state and restart the process.
Oracle recommends starting the Admin and Managed Servers through the Node Manager using python scripts and then configuring the Windows server to execute the python scripts at startup.
To start servers manually, see Start Servers Manually.
In this section:
Create boot.properties
Check if the boot.properties file exists in Oracle_Home\user_projects\domains\FRDomain\servers\AdminServer\security.
If not, create it as a plain text file with the following contents:
username = weblogic_username
password = weblogic_user_password
By default, the WebLogic username is weblogic. This username and password will get encrypted after all services are started.
Increase the Delay for Auto Start OPADomain and FRDomain
For the OPADomain and FRDomain to start successfully, depending on the performance in your environment, you may want to increase the delay by which OPADomain and FRDomain start to allow time for Node Manager to start first.
  1. Go to OPA_HOME\config\opa_setup_scripts\ directory.
  2. Open the autostartfrdomain.cmd and autostartopadomain.cmd files.
  3. In each file, find the line PING 127.0.0.1 -n x and change the value of x to 300.
  4. Save and close the files.
Set Up Scripts to Execute Automatically at Machine Startup
Create a task and set up the Task Scheduler to run the job on bootup:
  1. From Start, then Control Panel, then System and Security, then Administrative Tools, open Task Scheduler.
  2. Select Create Basic Task on the right side of the Task Scheduler.
  3. Enter following values:
    Name: Oracle FRDomainNM Autostart
    Trigger: When the computer starts
    Action: Start a program
    Select: opa_home\config\opa_setup_scripts\autostartfrdomain.cmd
  4. Click Next and then Finish to complete creation of the scheduled task.
  5. Find the task Oracle FRDomainNM Autostart under the Task Scheduler Library list. Right-click on the task you just created and select Properties.
  6. On the General tab, select Run whether user is logged on or not.
  7. Click OK.
  8. When prompted, enter the user name and password.
  9. Repeat the above steps for OPADomain Node Manager, OPADomain, and FRDomain, except for step 3 enter:
    • For OPADomain Node Manager:
      Name: Oracle OPADomainNM Autostart
      Select: opa_home\config\opa_setup_scripts\autostartopadomainNM.cmd
    • For OPADomain:
      Name: Oracle OPADomainMS Autostart
      Select: opa_home\config\opa_setup_scripts\autostartOPADomain.cmd
    • For FRDomain:
      Name: Oracle FRDomainMS Autostart
Test Autostart
To test:
  1. Restart the computer.
  2. Allow some time for the services to start.
  3. Verify that these URLs work and you can log into application:
    • Oracle Clinical: https://server.domain/opa52/launch.htm
    • RDC: https://server.domain/rdcadfsrnd/faces/Login
    If the URLs do not work after several minutes, check files in opa_home\log:
    For FRDomain:
    • autostartfrdomainNM.log
    • autostartfrdomainNM.err
    • autostartfrdomain2.log
    • autostartfrdomain2.err
    For OPADomain:
    • autostartopadomainNM.log
    • autostartopadomainNM.err
    • autostartopadomain2.log
    • autostartopadomain2.err
