Software Requirements
For technology stack updates, see Oracle Health Sciences (Life Sciences/ Pharmaceutical/ Healthcare) Supported Technology Stacks (Document ID 180430.1) on My Oracle Support.
OCT 2020 CPU is certified for Oracle Clinical 5.2.2. For the list of certified technology stack patches, see Oracle Health Sciences Critical Patch Update October 2020 (Doc ID 2711188.1) on My Oracle Support.
If you are applying the OCT 2020 Critical Patch Update, you may encounter an error while launching the OC application. To avoid this error, follow the instructions below:
Table 1-1 Oracle Clinical Database Tier Technology Stack
| Component | Supported Version |
Operating System |
Oracle Linux 7.2 with Unbreakable Enterprise Kernel (UEK4), 64 bit (US English) Oracle Solaris SPARC 10 and 11, 64-bit architecture (US English) HP Itanium 11.31; 64-bit architecture (US English) Microsoft Windows Server 2012 Release 2 (US English) Microsoft Windows Server 2019 (US English) for Oracle Database 19c |
Oracle Database |
Oracle Database 12c Release 2 (12.1.0.2) Enterprise Edition, 64-bit Oracle Database 19c Release (19.3.0.0) Enterprise Edition, 64-bit |
Compiler |
For Oracle Linux x86-64: GCC-4.8.5; command to identify compiler is For Oracle Solaris SPARC 10 and 11: Sun Studio 12.4 Sun C 5.13; command to identify compiler is For HP Itanium: HP C/aC++ for Integrity Servers B3910B A.06.12; command to identify compiler is |
Optional Software |
SAS 9.4—Note that if you install the Oracle Clinical database tier on Windows, you must install SAS on Windows. Oracle Real Application Clusters (RAC) on Sun, HP, and Linux, including Exadata Oracle Virtual Machine (OVM) 3.2 |
Table 1-2 Oracle Clinical and RDC Onsite Application Tier Technology Stack
Operating System |
For OC 5.2: Microsoft Windows Server 2012 Release 2 For OC 5.2.1: Microsoft Windows Server 2016 Standard For OC 5.2.2: Microsoft Windows Server 2016 Standard |
Oracle WebLogic Server |
Oracle WebLogic Server 12c Release 2 (12.2.1.4) |
Oracle Fusion Middleware Infrastructure |
Oracle Fusion Middleware Infrastructure 12c Release 2 (12.2.1.4) |
Oracle Application Development Framework |
Oracle Application Development Framework 12c Release 2 (12.2.1.4) Note: Included with Oracle Fusion Middleware Infrastructure. |
Oracle Forms and Reports |
Oracle Forms and Reports 12c Release 2 (12.2.1.4) |
Oracle Java Development Kit (JDK) |
Oracle Java Development Kit 1.8 Update 241 or later (JDK 1.8 is also known as JDK 8) |
Oracle Java Runtime Environment (JRE) |
Oracle Java Runtime Environment (JRE) 1.8, also known as JRE 8 |
Microsoft Visual Studio |
Visual C++ in Microsoft Visual Studio 2010 and 2012 (x64 distributed)—Required for Oracle WebLogic Server 12c (12.2.1.4) and Oracle Forms and Reports 12c (12.2.1.4). Also, can be used to invoke Data Capture API methods from custom clients. |
Table 1-3 Oracle Clinical and RDC Onsite Client Tier Technology Stack
Operating Systems |
Microsoft Windows 10; 32-bit or 64-bit architecture (US English) Microsoft Windows 7; 32-bit or 64-bit architecture (US English) Microsoft Windows Server 2012, Release 2; (US English) Microsoft Windows 8/8.1; 64-bit architecture |
Mobile Operating Systems |
iOS 11.4.1 (iPad) - for RDC Onsite only OS X 10.14.1 (MacBook) - for RDC Onsite only |
Supported Browsers |
Microsoft Internet Explorer versions depend on the operating system:
Safari versions depend on the operating system:
Adobe Reader |
Releases 8x, 9.x, 10.x, 11.x (US English) Required for viewing reports, including Patient Data Reports (PDRs) |
Adobe Acrobat |
Releases 8x, 9.x, 10.x, 11x (US English) Required for creating annotated layouts |
JRE 1.8, also known as JRE 8 |
Database Tier Operating System Requirements
To verify that your system fits the requirements listed in Table 1-1 do the following in UNIX or Windows:
UNIX
To verify UNIX operating system details, enter the following command:
uname -a
In addition, to verify the update version for Linux, enter the following command:
cat /etc/issue
Windows
To verify Windows operating system details, navigate to the Control Panel, then System and Security, then System.
Parent topic: Software Requirements
