Upgrade Oracle Database
In this section:
- Upgrade the Database to Oracle Database 12c Release 1 (12.1.0.2)
- Upgrade the Database to Oracle Database 19c (19.3.0)
Parent topic: Upgrade Oracle Database Server Code and Databases
Choose to configure the database to accept connections as a service instead of a SID. Service name requirements for Oracle Clinical include:
- The service name must be less than 15 characters long.
- It must not include the domain.
- It must be all lowercase.
The Oracle Clinical Installer no longer works if you set up connections using the SID.
If you are installing the Oracle Clinical database on a pluggable Oracle 12.1.0.2 database (PDB), see My Oracle Support article ID 1910177.1, How To Configure TNS / SQLNET using the local_listener parameter for Pluggable Database In Oracle 12c, Allowing a SQLNET Connection to the PDB.For more information, see:
If your Oracle database version is 12.1.0.2, you can upgrade the database to the 19c version.
Do one of the following:
Upgrade in Place from Oracle Database 12.1.0.2 to 19c
Follow instructions in the Oracle Database Upgrade Guide - 19c at https://docs.oracle.com/en/database/oracle/oracle-database/19/upgrd/ using the Database Upgrade Assistant (DBUA) option.
For more information, see Method 1 in the Upgrade and Migrate to Oracle Database 19c White Paper at https://www.oracle.com/a/tech/docs/twp-upgrade-oracle-database-19c.pdf.
Parent topic: Upgrade the Database to Oracle Database 19c (19.3.0)
Clone Your Database on a Oracle Database 19c
To clone your database on a Oracle Database 19c:
