Set Up Parameterized Submissions
The Parameterized Submission process (PSUB) schedules and runs jobs, reports, and batch processing for Oracle Clinical. In order to support using Oracle Real Application Clusters (RAC), the implementation of PSUB changed in Oracle Clinical 5.0. See the 5.0.1 Installation Guide for more information.
You must start one PSUB service for each Oracle Clinical database on the same server as the database.
For more information, see:
- Create Directories and Enter Values in OCL_STATE Local Reference Codelist
- Enable Users to Submit PSUB Jobs
- Set Up Active Directory
- Start the PSUB Service
- Customize the PSUB Service (Optional)
- Test the PSUB Installation
Parent topic: Install Oracle Clinical Database Components on Windows
See Integrate SAS (Optional) for information about new OCL_STATE settings related to SAS configuration.Parent topic: Set Up Parameterized Submissions
Beginning in Release 5.0, PSUB users no longer need:
- their own OS account
- a user name beginning with
OPS$ - their own directory for PSUB outputs under their own OS account home. (Instead PSUB outputs are stored temporarily in a user specific directory under PSUB root folder specified inPSUB_LOGS_DIR entry of the OCL_STATE local reference codelist. Then they are uploaded into database and can be viewed.)
New Users
To add new users:
- Use the ocl_add_user.sql script, indicating which new users need to run PSUB jobs.
See the Oracle Clinical Administrator's Guide for more information.
Existing Users
If you are upgrading from a pre-5.0 version of Oracle Clinical, to give users who need to run PSUB jobs access to the opapps account:
PSUB Administrator User
You can give a user the role RXC_VWJOBS (new in 5.0) to allow him or her to:
- View all users' jobs
- View the output from those jobs.
- Stop any job.
The following scripts can grant this role to a user:
- ocl_add_user—Use this script for new users.
- ocl_grant_revoke_rxc_vwjobs.sql—Use this script for existing users. (This script can also be used to revoke the role.)
If you are running PSUB on a Windows server that is a primary domain controller running Active Directory:
The Installer automatically installs the PSUB service on the database server. You must start it using on set of instructions below.
Instructions for stopping PSUB manually are included in the Oracle Clinical Administrator's Guide.
To start the PSUB service manually on Windows:
- Log in as opapps. (You set up the PSUB service to start as the opapps user, but in Windows you can start the service when logged on as another user.)
- Set the PSUB service parameters:
- In the Start menu, navigate to Administrative Tools, then Services.
- From the list of services in the Services dialog box, double-click the name of the database for this service. It is in this form:
PSUB Service database
- Enter values for the Log On parameters:
database code_environment[verbose | noverbose]value-of-RXC_ROOTwallet_aliasFor example:
prod 541 verbose c:\\opapps\\oc\\541 <wallet_alias>where prod is the connect string for the database instance to which the PSUB service connects;
where 541 is the name of the code environment;
where wallet_alias
is the name of the Wallet specified during installation.Note:
If your entry requires a backslash (\), you must enter two (\\). Alternatively, you can enter the path using single forward slashes, for example, c:/opapps/oc/541.
- Click Start.
- Exit from the Services dialog box.
- Check the PSUB service log file in <RXC_ROOT>\log for any warning or error messages.
For more information about managing and customizing the PSUB service, see the Oracle Clinical Administrator's Guide.
To test your PSUB installation:
- Open Oracle Clinical.
- Submit a 3GL job such as Batch Validation or a PL/SQL job such as Study Unfreeze.
- Verify that Oracle Clinical creates the log and output files by clicking on the View log and View output buttons.
If you encounter problems or errors, review the messages in the PSUB log files created in the following directory:
%RXC_ROOT%\log
