Software Requirements
Check the following links for the latest software requirements:
Oracle technology stack components, such as Oracle Database and Oracle Fusion Middleware are certified for use with Oracle Virtual Machine (OVM). For further information including a complete list of products/versions certified on OVM, see Oracle VM: Software Certified On OVM (Doc ID 464754.1) on My Oracle Support.
Upon release, Oracle Clinical 5.4.1 and Oracle Remote Data Capture 5.4.1 are certified for use with the latest CPU certified for release 5.4.1. For information on the latest certified CPU, see Oracle Life Sciences Applications Supported Technology Stack (Document ID 180430.1) on My Oracle Support > section Oracle Life Sciences Critical Patch Updates (CPU) Notes in the PDF file.
You must apply the latest CPU certified for release 5.4.1 after installing Oracle Clinical 5.4.1. If the latest CPU is already applied, remove it, install Oracle Clinical 5.4.1, and then apply the latest CPU.Table 1-1 Oracle Clinical Database Tier Technology Stack
| Component | Supported Version |
Operating System |
Oracle Linux 7.6, 7.7, and 8.1 to 8.7 with the Unbreakable Enterprise Kernel (UEK), 64 bit (US English) Oracle Solaris SPARC 11.4, 64-bit architecture (US English) HP Itanium 11.31; 64-bit architecture (US English) Microsoft Windows Server 2019 (US English) |
Oracle Database |
Oracle Database 19c Release (19.3.0.0) Enterprise Edition, 64-bit |
Compiler |
For Oracle Linux 7.6 or 7.7: GCC-4.8.5 or later; command to identify compiler is
For Oracle Linux 8.1 to 8.7: GCC-8.5.0; command to
identify compiler is For Oracle Solaris SPARC 11: Oracle Solaris Studio 12.6 Sun C 5.15; command to
identify compiler is For HP-UX Itanium: HP-UX 11.31 September 2014 B.11.31.1409 or later ; command to
identify compiler is |
Optional Software |
SAS 9.4—Note that if you install the Oracle Clinical database tier on Windows, you must install SAS on Windows. Oracle Real Application Clusters (RAC) on Sun, HP, and Linux, including Exadata |
Table 1-2 Oracle Clinical and RDC Onsite Application Tier Technology Stack
Operating System |
Microsoft Windows Server 2016 and 2019 |
Oracle WebLogic Server |
Oracle WebLogic Server 12c Release 2 (12.2.1.4) |
Oracle Fusion Middleware Infrastructure |
Oracle Fusion Middleware Infrastructure 12c Release 2 (12.2.1.4) |
Oracle Application Development Framework |
Oracle Application Development Framework 12c Release 2 (12.2.1.4) Note: Included with Oracle Fusion Middleware Infrastructure. |
Oracle Forms and Reports |
Oracle Forms and Reports 12c Release 2 (12.2.1.19) |
Oracle Java Development Kit (JDK) |
Oracle Java Development Kit 1.8 Update 391 or later (JDK 1.8 is also known as JDK 8) |
Oracle Java Runtime Environment (JRE) |
Oracle Java Runtime Environment (JRE) 1.8 update 391, also known as JRE 8 |
Microsoft Visual Studio |
Visual C++ in Microsoft Visual Studio 2015-2022 (x64 distributed)—Required for Oracle WebLogic Server 12c (12.2.1.4) and Oracle Forms and Reports 12c (12.2.1.19). Also, can be used to invoke Data Capture API methods from custom clients. |
Table 1-3 Oracle Clinical and RDC Onsite Client Tier Technology Stack
Operating Systems |
Microsoft Windows 11; 32-bit or 64-bit architecture (US English) |
Mobile Operating Systems |
iOS 15.0 (iPad) - for RDC Onsite only macOS Big Sur Version 11.6 (MacBook) - for RDC Onsite only |
Supported Browsers |
The following Microsoft browser and operating system combinations are supported:
Safari versions depend on the operating system:
Adobe Reader |
Adobe Acrobat Reader DC 21 or Adobe Acrobat Reader 2020 (Classic Track) are required for viewing reports, including Patient Data Reports (PDRs) |
Adobe Acrobat |
Adobe Acrobat Standard DC 21 or Adobe Acrobat 2020 (Classic Track) are required for creating annotated layouts |
JRE 1.8 update 391 or later, also known as JRE 8 |
Database Tier Operating System Requirements
To verify that your system fits the requirements listed in Table 1-1 do the following in UNIX or Windows:
UNIX
To verify UNIX operating system details, enter the following command:
uname -a
In addition, for Linux, enter the following command:
more /etc/*release*
Windows
To verify Windows operating system details, navigate to the Control Panel, then System and Security, then System.
Parent topic: Software Requirements
