Stop Servers
You can stop each server either in the appropriate WLS Admin Console or from the Windows Start menu.
These instructions are provided for your information; you do not need to do them now.In this section:
- Stop the Forms Server
- Stop the Reports Server
- Stop the FRDomain Admin Server
- Stop the Managed Server of OPADomain
- Stop the OPADomain Admin Server
Parent topic: Upgrade the Oracle Clinical Front End
The Oracle Forms Server is located on the WebLogic Server domain that must be named FRDomain and must use port number 7001.
To stop the Forms Server, do one of the following:
- Open a DOS prompt, and run the following:
ORACLE_HOME\user_projects\domains\FRDomain\bin\stopManagedWeblogic WLS_FORMS - Use the Admin Console at http://host:7001/console.
The Admin Console is available only if the Admin Server is running.
Parent topic: Stop Servers
The Oracle Reports Server is located on the WebLogic Server domain that must be named FRDomain and must use port number 7001.
- To stop the Reports Server, use the Admin Console at http://host:7001/console.
The Oracle FRDomain Admin Server is located on the WebLogic Server domain that must be named FRDomain and must use port number 7001.
To stop the Admin Server:
- Go to ORACLE_HOME\user_projects\domains\FRDomain\bin and run stopWebLogic.cmd.
The Managed Server of OPADomain is located on the WebLogic Server domain named OPADomain, which must use port number 7101.
To stop the Managed Server of OPADomain, use the Admin Console at either:
- http://host:7101/console
- https://host/opaconsole (if configured)
The Oracle OPADomain Admin Server is located on the WebLogic Server domain that the Installer names OPADomain, and which must use port number 7101.
- Go to ORACLE_HOME\user_projects\domains\Opadomain\bin and run the stopWebLogic.cmd.
