Upgrade Oracle Database
In this section:
Parent topic: Upgrade Oracle Database Server Code and Databases
Upgrade the Database to Oracle Database 19c (19.3.0)
If your Oracle database version is 11.2.0.4 or 12.1.0.2, you can upgrade the database to the 19c version.
Do one of the following:
For more information, see:
- Upgrade in Place from Oracle Database 11.2.0.4 or 12.1.0.2 to 19c
- Clone Your Database on a Oracle Database 19c
Follow instructions in the Oracle Database Upgrade Guide - 19c at https://docs.oracle.com/en/database/oracle/oracle-database/19/upgrd/ using the Database Upgrade Assistant (DBUA) option.
For more information, see Method 1 in the Upgrade and Migrate to Oracle Database 19c White Paper at https://www.oracle.com/a/tech/docs/twp-upgrade-oracle-database-19c.pdf.
Parent topic: Upgrade the Database to Oracle Database 19c (19.3.0)
To clone your database on a Oracle Database 19c:
