CDS Criteria Definition Rules
As you define your criteria you must follow these rules:
You can move the cursor to the CDS Criteria window from the RDCI Key Changes, RDCI Soft Deletes, RDCM Key Changes, or Response Changes window using the keyboard shortcut Ctrl+Shift+F8.
Unless you specified a DCM Name or DCI Book in the top panel, you must create at least one row in the bottom panel in order to generate a CDS.
You must enclose non-numeric data values in single quotes ('). See the example entries in the Value column in CDS Criteria Examples.
You can specify only one discrepancy criterion per mass change operation, and the discrepancy criterion must be the last one defined.
Include criterion types in the following order, with all Key-type criteria first, then all Response-type criteria, then the Discrepancy-type criterion:
Key
Response
Disc
You must enter AND between criterion types.
Parent topic: Defining Candidate Data Set Criteria
