Counting CDS Records
After you have defined the MCS, before or after specifying the CDS criteria, you can count the number of records the CDS contains, or would contain if it were created as currently defined. You can use the count as a test that the actual number of records you are to work on is within a reasonable and expected range. Obtain the CDS count at any time by clicking the Count CDS button.
Parent topic: Defining Candidate Data Set Criteria
