Defining and Using Format Masks
To batch-load data into Oracle Clinical, you must create or select a format mask with which you specify how the data in your files corresponds to fields in Oracle Clinical. Masks achieve this correspondence in two different ways:
- Positional masks define a length for each column in the data file; for example, the STANDARD format mask (described below) assigns the first ten characters to the Investigator, the following ten characters to the site name, and so on.
- Delimited masks have no set column length and separate column values with a user-defined delimiter character such as a comma (,). Flexibility in field length can save space.
You cannot load multibyte data using positional format masks, including the STANDARD format mask supplied by Oracle. Use delimited masks for this purpose.Oracle Clinical ships with a predefined format mask of the fixed or positional type. You can define your own format masks as required.
See the following:
- STANDARD Mask Format
The STANDARD mask is the format used by default when a new data file is created. - User-Specified Formats
- Normalized Lab Data
Parent topic: Setting Up for Batch Data Loading
