Deleting DCFs
If you entered the wrong criteria for the information you wanted to include in the DCF, you can delete the DCF and create a new one. You can delete a DCF only when its DCF Status is CREATED, DRAFT, CLOSED or FINAL. To delete a DCF, select it in the Maintain Data Clarification Forms form and perform a delete operation. If the operation fails, the current status of the DCF does not permit deletion.
When you delete a DCF, the system releases all discrepancies associated with it.
